My surface pro 4 is I5, 8G, 256G model. In daily using, I find some system booting problems.
1. pause at the welcome screen and show " invalid handle".
2. keep loading at the welcome screen for a long while, after that show "C:\\windows\system32\config\systemprofile\Desktop invalid" and all irons on the desktop disappear.
3. everything seems OK, but the start menu doesn't work.
I tried to reset the system and reinstall the system, but the problems are not solved.
Does anyone meet these problems? How to fix it?
