Can I leave my Surface Pro 4 plugged in without affecting the battery life?
can i leave my surface pro 4 pluged in without affecting the battery life?
And, can it be unplugged without being fully charged?
Re: can i leave my surface pro 4 pluged in without affecting the battery life?
You should be able to plug it in all of the time and unplug at any time without affecting the charge. The lithium ion batteries are not messed up by these problems related to nickel batteries. The biggest culprit to problems with battery life are related to heat which degrades the battery. So make sure the fan is free when using it, especially if you hear the fan kick on.
Lesley Thomas
