HY.....!!
i was having storage problems...(typical)...so i decided to reset my phone...b4 the reset amber update was available....after reset..the catalogue list was gone...and update came ....actually 3..after the update...there was no storage check or something like tht..only data sense was new thing....nthing was to b found...idk wht 2 do...should i reset the device again...or wait 4 some miracle...?
#G
#G
