Volume problem
I have a 2 year old Nokia 928. I can hear callers quite well but the caller (or person I called) can not hear me. I turned the volume all the way up. Bluetooth is turned off. Any suggestions?
Low volume
I have a 2+ year old Nokia Lumia 928. I can hear callers quite well but the caller (or person I called) can barely hear me. Bluetooth is turned off, and the volume is all the way up. Any ideas what might be wrong. This just started this week.
Re: Low volume
check to see if this happens in other areas like skype or whatsapp calling - if it still happens, then the mic has an issue
Threads Merged.
User... Please do not create multiple threads on your issue. It actually works against you as any advice gets scattered around and a coherent conversation cannot develop as easily...
I took my phone to Verizon and you are absolutely right. The microphone opening was all clogged up with gunk! Works great again. Thanks for the suggestion.
YeOldRam
