NFC problem
JoeDizzle33
77
Does Nokia 920 support the tap to pay feature. I don't have an option to turn it on, I thought 920 supported that feature.
Have you played with the wallet app?
Sent from my RM-821_eu_euro1_342 using Board Express
From the Windows Phone site:
Why can't I make NFC transactions with my phone?
While every Windows Phone 8 has a Wallet Hub, not all support NFC transactions. The easiest way to check and see if your phone supports NFC transactions is to go to your Wallet settings. In Wallet, tap More More icon, and then tap Settings+PIN. If you don't see an option to turn on "NFC transactions," then your phone doesn't support it.
At the moment, only a small number of mobile operators offer phones that support this feature. However, we're working hard to get additional mobile operators on board, and we expect the number of Windows Phones that support NFC transactions to grow.
Lesley Thomas
