Problem with photo hub main(home) screen
Wow! Never seen anything like it!
I can only give 2 suggestions,
1. Try a hard reset.
2. If hard reset doesn't help, then i would guess its a hardware problem and take your phone in for replacement.
this problem only occur on photo hub main page. :/ maybe i installed some buggy app? need more advice before i do hard reset, i dont want to waste my time to install apps and setting again :S
Then try uninstalling all the photo related apps and see wether the problem is solved.
Since photo hub is a system app, the only way to reset it is by a hard reset.
performing hard reset....
and problem slove
Hard reset is first line of defense? **** no...
Try a soft reset first if you haven't already. THAT should ALWAYS be the first step in trying to resolve an issue, not a damn hard reset!!!
sixsigma
