Can I get some help with a Recovery Tool problem?
NokiaLumiaUser
40
Recovery Tool Problem
I have trouble with Windows recovery tool. Downgrade from win10 to 8.1. I have downloaded the program, and firmware. When I click next to install it, windows says "Thor 2 has stopped working". Any solution?
Re: Recovery Tool Problem
Thor 2 has stopped working?
Are you sure you've got the original program and not a fake one?
Yes, I have downloaded him from official's site. I have solved the problem. In cmd -> sfc / scannow helped.
I'm having the same problem trying to rollback an 830... Could you share how you got it working?
yagoldt
