1020 owners, any overheating or battery issues discovered?
I occasionally have the overheating and battery drain issue. It seems certain app will trigger it even if I had turned off the background task, Tether-X Pro is one of the suspects, but there are definitely others. As a developer myself, I believe it's a bug in the OS or firmware not the app even though the app have triggered it.
For me it happens with Nokia Creative Studio
Had my Lumia 1020 for a day now. It was fully charged last night and when I woke up in the morning it was on about 15%!!! I let it drain and die before charging it to 100%, been using it for 2hrs and 17 minutes, took a few snapchats, looked at fb couple of times and did some text messaging and a few pictures; am now on 75% which is not too good considering. So I put it in airplane mode and battery saver, it is now draining at 15% per hour! There is some serious issues, I have already done a hard reset once. If this doesn't clear up by a weeks time I will be sending it back and will be very sad to see it go as it is such a great phone. Seeing 75% battery left with Estimated time remaining as 5 hours is just unacceptable in my opinion.
If it still drain the battery, even after an hard reset, I'm afraid you have to return in... There might be an hardware issue...
My 1020 consumes about 1% over night in airplane mode...
My battery as of now (first charge) is mediocre at best. My 920 was alot,better but I'll give some time and see what happens.
Location off
WiFi off
Bluetooth off
And only four background tasks
Button click sounds off
Double tap to wake off
Glance is in peek
Hopefully after a couple of charges it will get better than this. I'll be lucky if I can get 8 hours low usage out of this.
My advice to you is to let the battery fully out of juice till the device turn off , then fully recharge your Lumia , that will make the battery life goes better and for better performance.
tnomtlaw
