- Dec 17, 2013
- 79,527
- 170
- 0
Got yourself a Netgear router? Here are some quick troubleshooting tips.
If you're using a Netgear router, then first of all, you made a good choice. While the apps you use to interact with it might not be the greatest feat of design, when it comes to performance you're being well looked after.
But, there are also some common issues you may want to address but aren't sure where to start. Here's some quick troubleshooting tips.
Full story from the WindowsCentral blog...
