A problem in lumia 520 i need a help
Aladini Mahmoud
20
I've bought nokia lumia 520 and i have a problem i need to explore files from the device not from the micro SD .
Thank you for fast response i know that not problem ,but i have moved a document pdf form my computer and i can't found it , what should i do ?
Where did you copied the PDF file ? Try sending the PDF to yourself via email on your Microsoft id and then download it , it will surely open in adobe reader , or try to upload the PDF file on one drive (formally sky drive ) and then open the file from cloud
Michael Niehaus
