Battery Hourly Consumption question--Battery Pro+ app
gallio
22
Hello all,
I have a Lumia 1020, and I downloaded the Battery Pro+ app to monitor my battery drain.
My question is, how is the hourly drain rate calculated? Mine consistently says 6% hourly drain which I think is kind of high. The problem is, the battery does not drain nearly that fast. I will leave my phone unplugged overnight and it goes from 100% to 98% in 8 hours of stand-by, yet the app still reports a 6%/hr drain rate.
Perhaps I'm being OCD by wanting it to report correctly, but has anyone else experienced this? I have soft reset and done everything aside from hard resetting my phone. Perhaps I do need to perform a hard reset.
Any input would be appreciated.
deadwrong03
1,028
I'm not sure I have a Lumia 928 with battery issues in getting around 21% hourly consumption trying to figure out why its draining so much and so fast. My percentage seems about accurate
Sent from my Nokia Lumia 928 using Tapatalk
BobbyJasht
