battery life from 100-0 in less than 90 min using kik only ..
ala kafi
5
is this normal ? i mean no other background apps working or anything ..just wifi + kik
even the brightest is very low cuz i'm using it at nights
ajeesh yacob
123
that s absolutely abnormal.
with amber i got 100% at time since last charging 6 hours with wifi on.
u should do somethin before warranty gets over
and i vent used kik,may be if its culprit,check phonw without kik n wifi on
ala kafi
5
yes sometimes it does get hot
i know kik is battery eater .. but I mean 90-80 min :!!!
my friend with Samsung s 4 using it for 5 hours with 50 % battery left
Sakeeboy
46
Kik is battery eater on WP. Plain fact! Kik team doesn't give any love to WP as the App was last updated 2/27/2012.. WhatsApp has been getting better and better though..
ala kafi
5
its lumia 920 obv .. no background apps running ..wifi not mobile data as i said in the title
i just want to know if its hardware problem .. or this is normal for everyone
anon(7900571)
8,034
Its time for you to to get a replacement of your device. There must be some problems with the battery. Head into the nearest service centre and tell them the problems you phased. If it is under warranty you are lucky they will replace it.
Sent from my iPad using WPCentral Forums mobile app
Tragic
16
Kik for windows phone is just a port or a version and android that was updated in the beginning of 2012. Its going to have better performance on a android phone because it is constantly being updated for that OS and has improved batter performance as well.
jonathan sink
137
I know for me its lte that kills my 920. If I turn it off when I'm only wanting calls or text then back on for email, or videos my 920 last for almost 2 days. However if I leave it on whether in use or not its dead within 8 hrs.
BobM65
