Battery not Charging to 100%
kevinrstruck
30
Left my phone on the charger all night (8+ hours).
When put on the charger it read around 62%, when I got it up it was at 92%.
The night before same thing, never got past 94%.
Does it take over 8 hours to charge this battery from 62% or is this battery not capable of fully charging?
If you are plugging into the wall with the nokia charger it should take around 2 or 3 hours or so to fully charge from 0%. Sounds like you might have a faulty charger or battery.
Yep. Are you using the Nokia charger plugged into an AC outlet (not a USB port). Charger must be rated 1A to properly charge the L900. Some chargers are only 650-750mA.
Sent from my Lumia 900 using Board Express
I had this problem when wifi was ON. With wifi turned Off it went to 100% .. try that...
My WiFi has been on since I got the phone last Friday. Of charger I am between 98-100%. The little difference is the battery charger cycling after it has reached full charge. But 92% is a problem. Based on my monitoring the homebrew Battery Status app, full charge cycling is between 97-99%.
nnnnkjkj
