battery saver BIG PROBLEM
WPCentral Question
1- i make battery saver on and choose "only when battery is low"
so the phone should enable battery save only when battery is 20%
2- my battery is 98% and the phone is in battery save ... so how this could happen but the shield is not appears inside phone it only appears on glance screen
f028e124
You can try this: Disable Battery saver, soft reset the phone (Press power + volume down buttons until it vibrate) and then enable Battery saver again.
igor640
