Battery saver shows "Phone" killing battery
Phone looks like all the antennas, those draw a lot of juice, so it should be high on the list.
P.S. Being on bluetooth doesn't matter, "Phone" is likely the juice being sucked down by the antennas, which is a pretty good amount when you're on a call (or roaming.)
I have the same problem... Phone is up to 80% while second thing is a game at around 20%. I talked for 5 minutes only, wifi on, bluetooth off.battery life is now at around 19hrs (lumia920) all background tasks are off... Any help?
Yes, noticed same thing today for me as well. Never had this problem before. Must be some wicked bug in calculating phone battery consumption. The phone behaves normally otherwise. No excessive battery drain noticed.
Echhean
