Has anyone else had an issue with this phone and the dev preview where you'd lose a Bluetooth connection, and then not be able to reestablish? Here's the scenario I've got:
1-BT enabled, headset connected, everything is fine
2-BT still enabled, but headset connection drops
3-Go into the BT menu, devices all show as "paired".
4-Tap on a device to try to connect, goes to "connecting"
5-Disable BT-progress bar that never completes (dots at top of the screen)
Alternatively, I can try to disable BT first (which works) and then reenable, but when I enable BT it has the same infinite progress indicator. Only solution is to then power cycle the phone, at which point I'm back to step 1.
Seems like something a new firmware might have to fix?
