Build 10159 - Issues, can I get some help with a fix?
Hestev
14
Dear All,
I have updated my Surface Pro 3 with the build 10159 and I have the following issues:
- Meteo app is corrupted: I have rectangle instead of icons;
- Mail and Calendar crash when I tried to open them;
- Store downloads and installs 26 metro app again and again
- Spartan, Winstore, Windows insider remain in my starting panel as at{....;
Am I the only one? Any fix?
Regards
Re: Build 10159 - Issues
I am having the same issue with mail and calendar. I can't use them at all.
I have updates in the store but they barely seem to move to download. It seems to freeze up. Open it again and it seems to move. However many apps will not open from start menu, either tiles or the links. I have re-booted to know success. Build 10158 was great but 10159 is sucking big time.
only problem I have is Chrome won't work at all pinned to taskbar. Mail/Calendar are fine, make sure to update the apps in store
I get fps lock issues, where my games are locked at 60fps on my gtx 780 120hz monitor.
