Can I get some help with wireless hotspot problems in 10166?
greg10e
11
Wireless hotspot problems in 10166
Having trouble with wireless hotspot in Build 10166 on a Lumia 930.
I can activate it and it all looks good. When I try to connect to it with another device, it connects okay and appears to be working properly.
However, the wireless connection on the connected device tells me there is no internet connection available.
Despite what device I try to connect, it still can't find an internet connection through the wireless hotspot.
Anyone else have this problem?
Not sure if it's the build, my Lumia 930 or Optus playing mongrel with tethering.
Never had the problem on 8.1, so I'm guessing it's some "feature" in Win10 that prevents me from downloading "too much" (read "any") data on a mobile plan.
Appreciate some feedback from other users.
Re: Wireless hotspot problems in 10166
NL 630 dual sim, same problem. Started with the very first release, tried 10149 the problem was still there.
And 10166 same issue. Unbranded phone using prepaid.
Michael Niehaus
