Case for the 1520 that will work on a tripod mount
Amrish Tandon
Any suggestion/recommendations on a case for the 1520 that will work on a tripod mount? Looking for something similar to the Camera Grip accessory available for the Lumia 1020.
Hey, what tripod do you have?
Sent from my Nokia Lumia 1520 (RM-937 Malaysia) using Tapatalk
Don't really have one. I want to get a case/mount for the phone first and then get a tripod/monopod that will work with it. Any suggestions are welcome.
You could get a Tripod with a Phone Holder, something similar to this or this, or just the top part, a Phone Holder, to screw on your own tripod. I haven't tried either of thee and don't know anything about their quality or compatibility with 1520, but it seams to be the right concept for putting 1520 on a tripod.
Tripod mount for Nokia Lumia 1520 (DIY)
Hi even i am stuck in the same field. I searched and got nothing but what is called {BEASTGRIP} i dont know if u can buy it online. So i made a mount using MDF and its working fineWP_20150415_21_55_41_Pro.jpgWP_20150415_21_53_33_Pro.jpgWP_20150415_21_53_37_Pro.jpgWP_20150415_21_56_14_Pro.jpgWP_20150415_21_56_20_Pro.jpg
BeastGrip seems to be the ideal answer... But I can never find them in production. They got pulled from Etsy and the Kickstarter finished, but we are still waiting.
I have one of those spring-loaded brackets such as Sam_oslo linked to and it works OK for my monopod and mini tripod, but it is a tight squeeze on a 1520 + TPU case. Does hold the phone sturdy and attaches as a universal tripod mount.
longinotti101
