Clean Battery Saver info?
BrunoShady
96
It's possible to clean the battery saver information about the battery use?
I want to charge until 100% and then clean the use information, to track again the use... it's possible?
I'd like this too but I can't find any was to clear it!
What's the point of knowing that maps consumed a chunk of battery at some point 5 charges ago? Without being able to reset to zero, battery saver is useless!
You'd think someone would have pointed out this at coding time, wouldn't you?
I haven't looked into this fully yet but does it not refresh the data when you put it on charge?
Hey guys, the battery info per app is shown for the most recent 24 hrs. Stuff that is older than that is not part of the displayed info. One easy way to clean it up is to leave the phone on the charger for 24 hrs, as power consumed while on the external charger is not included in the data.
where did you get this info?
Soft reset did it for me.
ETA:Hmm...it worked for me yesterday....Just tried a soft reset and battery usage levels stayed the same...sorry.
After a full charge last night my data didn't change & still showed up - would be nice if it did reset to zero after a charge then at least you would know what was using the battery for the current charge.
Did a soft reset earlier & it had the opposite effect on my battery data. Mine now shows the first 15-20 apps in the list as having full usage against them (full blue bar).
Would it be possible to add a simple button to 'Clear Stats'. Waiting 24 hours to initiate a test is an ugly work around. Sorry.
Michael Niehaus
