How can I fix a usb connection issue in build 10581 after factory reset?
how can I fix usb connection issue in build 10581 after factory reset?
I did a factoy reset on my LM 930 and since then I cant connect my phone to my pc via USB cable. has anyone an idea how can I fix it?
Re: how can I fix usb connection issue in build 10581 after factory reset?
Me too have same problem in my 830 after i reset the phone in build 10581.
Some1 said,WDRT can solve problem ,try connecting the phone via WDRT and after some time it will said to soft reset the device ,power+volumedown,after restart ,phone will b recognise by WDRT,downgrade to 8.1 and then everything will b normal..
I had not tried it yet.
The USB driver on your phone is corrupted. The only way out is to downgrade to WP8.1 using Windows Device Recovery Tool or Nokia Software Updater. Hope this helps.
After connecting for sometime ,when device is not recognize,u get a notification to soft reset ur device using power+vol down key.& thn WDRT recognised ur phone,n u can downgrade.
Hey everyone who is having problems with USB still. I was having the same issue. I went to the Microsoft store and he got it working. He said all he did was Hold either the UP or down button while you plug in the USB and it will force it to connect. Hope this helps.
abcdzoony
