How do I get my wireless Samsung printer to work with 10?
how do I get my wireless samsung printer to work with 10
The wireless printer worked before I downloaded windows 10. What do I do now?
Re: how do I get my wireless samsung printer to work with 10
Hmmm...printers...my nemesis...
At home, I was able to plug in my printer via USB and it auto-installed the correct driver. So definitely try that first.
Next, try going to the control panel and add devices/add printer and see if the drivers are in-the-build (they usually aren't, and that is the manufacturer's fault, not Microsoft...I should know, my first 10 years at Microsoft I worked with drivers)...
If they aren't in the build, you should have an option to get newer drivers via Windows Update. This should work, if not, go to the manufacturer's website to get the drivers.
Michael Niehaus
