How do i get Word Flow to work in languages other than ENG?
WPCentral Question
Changing the language on the keyboard effectively turns Word Flow off. Adding languages in Settings does not help. Adding keyboards in Settings does not help. I was told by Microsoft help that it depends on my mobile carrier. This seems unlikely, especially considering my carrier is in the German part of Switzerland, and I can use Word Flow in ENG but not in DEU (German).
You must first add the Keyboard under Settings. Note that a keyboard such as French (Switzerland) is a special layout that is not supported by Word Flow, while French (France) is supported. Open Settings, Keyboard and "Tap to change" the desired language. Tap "Suggest text" if it is not selected. If Word Flow supports the keyboard "Type as I swipe through letters" will be an option available and also needs to be checked. Now, when you change to that language on the keyboard, Word Flow will continue working.
longinotti101
