How low will it go? 925 for $200.00
am interested in this deal but the one question is, how hard would T-Mobile make it unlock it as I don't intend to use in the US
They won't unlock it until its been used on T-mobile for x days. The last T-mobile phone I unlocked x was 40 days. So $60 for 2 months of unlimited text and data and 100 minutes talk would probably be the cheapest if you had 40 days to spare. I'm not sure if they would unlock as soon as the 2nd month is prepaid since thay already have over 40 days of money by then. I saw a company that sells unlock codes for over $100 so it can be unlocked anytime for the right price.
I actually just bought this on HSN for $200. It was $216 total with tax. It'll be my first Windows Phone, although, it won't be my main phone. I'm currently using a LG G2 with Android but wanted to check out WP to see how it compares with day to day use. I will also be unlocking it, either through a 3rd party or through T-Mobile, so I'll come back and report on how that goes.
I should have waited - but when is the end. I got mine for 229 last week with different packaging and call HSN, they will not refund the $20 dollars difference. It is still a good deal for me. I will unlock it after 40 days with T-Mobile, I want to get the windows 8.1 especially the VPN function if I am going to connect to my company. Windows phone is not certified in my company becuase of that. Since the phone is going so cheap I am afraid that T-Mobile may not push the 8.1, unless it is unlock and I can get it from Microsoft.
Is the replacement electronic plan worth it from HSN? ITA $25 I think
Posted via the WPC App for Android!
It looks like it only covers manufacturer mechanical or electrical breakdowns for two years so it doesn't cover if you drop it and crack the screen or drop it in the toilet. You're probably better off without it. I'm sure Nokia has a standard one year warranty for that kind of stuff (the mechanical or electrical breakdowns not toilet drops) anyway.
Square Trade has a two year protection plan for $99 but there's a $75 deductible for all claims. That probably isn't worth it either. I'm sure if you do happen to break it or crack the screen it would be cheaper in the long run to just pay to fix it yourself or buy another phone rather than go through the hassle of a warranty-type plan. It's up to you though.
niedrie
