Low Light Picture Quality
Guzzler3
1,398
For those who have updated to GDR3, have you noticed that the picture quality in low light has improved over GDR2 on the 810? But only with the default camera lens. The custom Nokia lens's still have issues.
Anyone else notice this?
Do you have Pro Cam on you're 810, I do and it's just the same as before but then again that is a NOKIA lens not an MS lens.
I don't have the Pro Cam installed any more. So I can't comment on that one.
But how is the default lens for you?
Lots of light space and dark object approx 1/8 sec hand held auto exposure
light source (1) 40W clear incandescent bulb and ambient florescent light from bathroom shower
to test limits of the lenses and auto exposure and WB in low light
One with Pro Cam one with Built in I think White Balance set on auto is perfect -white walls are white
with a little refection and shadow from the hutch and brown tile causing some brown hues on the ceiling. Hutch is grainy but
color is correct.
NOTE: I just looked at properties and details for the built in photo and in details it said 3200 ISO even tho' in the camera settings it only goes up to 800.
that is why low light is better after GDR3.
I checked another photo taken with built in and ISO is 1000 and we know that in settings highest ISO is 800 so that has changed
I installed the Nokia Camera just now using the Fiddler workaround, and I must say, awwww yeaaah! The picture quality has definitely improved!
hosseinf
