Model of Lumia 930 and problems
bluekalo
47
my lumia 930 is RM 1045_1025 and the problem is microphone audio recording on windows 10 using voice recorder app and any other voice recorder does not work and loudspeaker mode during calls does not work
hey cortana works
video recording with audio works
microphone on keyboard works
whats on yours?
Use the test application and you'll know everything about each of the microphones. Then find nearest service point and take your phone there, as it will need to be repaired. I bet it will.
The most problems are with HW revison 2.0.0.2 and 2.0.0.3
HW revison 2.0.0.1 and lower are without any problems (not only microphones)
HW revision 2.0.0.3 here, 18 months of use and a couple of drops. Zero issues with mics etc.
A friend of mine had another just like mine (bought them together, same seller), his was working fine for over a year until he got another phone.
My 930 after W10m update sucks battery drain fast , heats up crazy and loads of app crash hardware revision 2.0.0.3
Michael Niehaus
