,,Music Locker" rapid and crazy battery usage+draining
Marko Marjanovic
264
I swiched to ,,music locker" app couple od weeks agi, everything worked flawlesy but couole of days ago it stard heat my 1520 like crazy and drain battery more and more rapid. In my case when i lisen music my music app (doesen't matter wich one) don't accualy drain more then 1-2% in ,,batery saver" app, couple of days agonit started go like 10-20% (even if i play music for a min or so). I heavely use ,,what's app" and draining is like 5% at most, this one is waaaay beyond that.
Thought is ,,buged" so i soft restart phone, reinstal, re-scan device and even remove my sd card nd transfer all music (around 2,000) to phone internal memory. It's the same.
I even tried to use stock music xbox app and problem is still there but not so much, still my phone act like i'm browsing web 20h straith. It's hot (it's 1520 i know but something about ,,music" is causing the problem.)
Is it to sd card, should i not use my sd 16gb 10class card at all?
Should my phone need to hard reset (it been awile since i did that) ?
Ps. I didn't add any more music so i can say some corrupted file is causing it.
Can you try disabling "Download artist photos", I'm wondering if there is a bug related to it causing this behaviour. Let me know..
edit: sorry, I missed the part where you said it didn't matter which app. I didn't sleep last night :cry:
1337GameDev
