my nokialumia 920 is not turn on after update even i can do soft and hard reset plzzzzz help me
WPCentral Question
I can do even soft and hard reset but my nokia lumia 920 is not turn on
Did your phone run battery die during the update? If so you need to plug it in. If it has a charge then try the soft reset first. Even if you think the phone is charged I would put it on charge for at least an hour.
Be sure to hold volume down and power button until the phone vibrates. This may take longer than usual especially if the phone is in a locked state.
If that doesn't work you can try this but take note of the warnings. This is taken from the support site.
The problem you are experiencing may be caused by a software problem on your phone. You will need to perform a factory reset to try and resolve the problem.
Please note: All information on your phone will be deleted and anything that has not been backed up will be lost during this process. If you cannot access your phone's menu, unfortunately you will not be able to back-up any data.
Make sure your phone is powered off.
Press and hold the 'volume down' button.
Press the 'power' button until the phone vibrates, then release the 'power' button.
Keep the 'volume down' button held until you see an '!' on the screen, then release the 'volume down' button.
When the '!' appears, press the following buttons in order:
'volume up'
'volume down'
'power'
'volume down'
You should see rotating gears on your screen for around 5 minutes.
Your display will then turn blank for 30 seconds while your phone restarts.
It will take several minutes for your phone to restart. Once your phone has restarted you will need to follow the on-screen instructions and complete the initial set-up process on your phone.
longinotti101
