Nokia 930 issues / Help - Camera, Wifi, Living Images
rikstarr
Hi
Im having problems with the following, anyone else? or any advice? This is not an android to windows rant (although windows has ALOT of simple things that needs doing that would make life easier)
1 - Wifi keeps dropping, my 4 year old android phone has better wifi connection that my 930 and i loose connection in my room
2 - everyones seems to be over heating, even after a few mins use
3 - Living images no longer play in my gallery, they did when i captured the shot and a few mins after, but days after when trying to view, there is no movement in the photos
4- Camera, the night time shots are awful, they appear grainy, any advice? i just shot with everything on auto, i played with the ISO but no luck still.
Thanks
2: Check your email sync settings and make sure it's not set to "Based on my usage" or "As items arrive".
3: Living Images only play in the Nokia Camera camera roll and not in the Photos app. So it's not playing even in Nokia Camera?
4: The ISO is too high (1250) in the photo that you posted. Anything over 400 will produce soft and noisy photos.
1. Make sure you have wifi set to not drop when you lock the screen. No idea why this is on by default.
2. My 930 doesn't overheat. Poke around the forum and see if you can find a solution.
3. Answered above
4. Learn to use the camera before you complain
I made an hard reset, reload all the same applis + datas and wifi stays stable. How long ??
I just turned off living images. It was cool to see very briefly but seemed gimmicky and pointless. Especially since It doesn't even do it in the camera roll where I go to scroll through all my pics. I think it also improved shot to shot time too since it doesn't have to record a tiny half second video.
Night shots require some camera know-how to get good photos. It just doesn't do very good on auto.
Jeniferbrowns
