Please i need fix for the problem for Lumia 730
Abdullah_Naeem
18
Please i have posted my problem in another thread. Any person please reply me ? I am extremely fed up with this.
Yesterday night i installed Navmii a navigation application on my Lumia 730 with denim update on. The app is like that its incomplete (i am sorry as i am not a developer so cannot explain perfectly)
For every buttons and options there are codes/commands. I downloaded local maps some how.
After that my cell phone is hanging. Screen going off and is not coming back unless made a soft reset. Network not working. When i put ir on charging the screen comes but then it does not go off again.
My lock button not working after installing the stupid app. But prolonged press working. Hence able to soft reset. Soft reset done around 10 times till now from yesterday evening.
I uninstalled app. Some things are fixed but screen off and soft reset is still major issues.
What to do ?
I have posted in Q&A section but got no response from any expert. Please help out
My cell is in warranty but never want to do hard reset. I have to back up a lot of data and then it takes time to restore and setup every thing again. Any other option please ?
Can you remove the Navmii app? If you can, do that, then reinstall. If you can't, go to Windows Phone Store and Reinstall the app.
Navmii installed for me with no problems. However, when Extras + Info was being updated yesterday evening, for a short while it appeared as a long code. Once it had completely installed, the proper name appeared. So to me, your problem sounds like an incomplete install.
I have uninstalled the application already. It makes worst with it installed on my cellphone. System goes dead. I have moved to Developers preview as well but nothing changed. Same lock button hanging issue. Its not working have to do soft reset. :(
tnomtlaw
