Problem with Mail and Calendar app draining battery in background, what options do I have to decrease battery drain?
Slavko Petrovic
I am using L640 with W10M .164 build and I'm quite happy with it. This morning, when I opened "battery use" in "battery saver" I noticed that Mail and Calendar app drained aproximatley 45% of the battery, almost all of that as a background process. Later I contacted my friend who has L830 on the same build and same app is on top of his battery draining list, also as a background process. My questions are:
-I doubt that is normal, so what should I do to decrese this abnormal background battery usage of the app?
-If I just turn off ability to work in background for Mail and Calendar, is there any negative consequences beside need to manualy sync mail?
Thanks in advance!
Re: Problem with Mail and Calendar app draining battery in background
Thanks in advance!
You can safely disable mail in background and I would recommend it in fact. You would have to sync mails manually. That's not a big thing really. I do that 2-3 times a day and I don't miss much. Your battery will last longer of course and that's the good thing
freddieleo7
