I heard you liked RGB lighting?
If you're planning to maximize the amount of colored light bouncing around inside the best PC cases, you'll usually want to use fans and strips that are equipped with RGB LEDs. These are then controlled through the motherboard or a dedicated RGB hub that interfaces with software to let you customize what's on show.
What if I told you there was yet another way to light up your PC? Cables have been modded for many years, usually to replace the plastic OEM connections with premium-looking braided aftermarket solutions. These don't have RGB lighting, however, which is precisely where the Lian Li Strimer Plus V2 comes into play.
Full story from the WindowsCentral blog...
