Strange connectivity issue.
Ruined
487
I am wondering if anyone experienced this problem:
1. On both LTE and WiFi, occasionally I will lose data connection (no internet on all apps), but phone status bar reports signal is good. Data usually comes back in a minute or two but sometimes requires a phone reboot.
2. After losing service (I.e. Subway) regaining the data connection on lte is occasionally an issue, sometimes requires phone reboot. Again phone reports strong signal even though data does not work.
Anyone else experiencing this? Hoping denim will fix it as it seems like a weird bug that only occurs intermittently but.usually at least once ever other day. Thx.
I've had that before. Sometimes it takes two or three reboots before I get my data connection back. Has happened on 8.0 and 8.1DP.
Oh but not as often as every other day. Has happened probably 5 times since I bought the phone shortly after launch.
Under settings -> cellular+SIM, do you have "use cellular data" for Limited Wi-Fi connectivity. It fixed the issue for me.
YeOldRam
