surface book - dock - monitor compatibility problems
Balazs_Bernat
hi,
I recently purchased a surface dock (model 1661) for my surface book, but it doesn't work with my monitor (dell p2416d). I know it doesn't support some monitors but mine is fine according to this list. I use a DP - mini DP cable, but I also tried it with an HDMI cable with a mini DP adapter, to no avail. I also updated the FW on the display dock, still - nothing.
any ideas?
hi,
any ideas?
What is it doing when you try to use it? Also, is the dock working with other accessories? Mice, keyboard, etc?
it just doesn't work, the laptop sees that there should be a second screen but I can't set it to duplicate/extend desktop, or to show desktop just on the monitor screen. when I unplug it from the dock, the monitor displays the "no source, going to sleep in 5 min" message (or sg like that), while it is just pitch black when plugged in, so there is definitely _some_ connection.
works fine with everything else, be it keyboard, mice, external HDD, audio jack, even the usb hub built in the monitor.
Michael Niehaus
