- Dec 17, 2013
- 79,384
- 167
- 0
Not sure if you should go for the Surface Go or Surface Pro? Hopefully our comparison chart can help!
Looking into buying a new Surface tablet? You've got two different devices to choose from now. There's the Surface Go, and the Surface Pro, which are very similar on the outside but rather different on the inside. Depending on what you're planning to use your Surface for, maybe you could save a few bucks on a Surface Go? Let's compare and contrast.
Full story from the WindowsCentral blog...
