Surface Pro 3 m3 vs Surface Pro 4 i7
Hi,
I am looking into buying a surface pro. The lowest specced model of the surface pro 4 is around £700 and ships with a the following:
- Intel Core m3-6Y30 Processor
- 128 GB SSD
- 4 GB RAM
However, a refurbished surface pro 3 is around the same price and has the following:
- Intel Core i7 Processor
- 256 GB SSD
- 8 GB RAM
If it were you, which device would you be buying?
Between those two, the Pro 3 definitely. I am a moderate-to-demanding user and I will make use of all 8 GB of RAM as well as the storage.
But out of all other computers, I would go for something easier to repair because when the battery goes on either model, that's the end of the Pro as far as portability is concerned.
fc806063
