USB cable issue, can I get some help?
Silwncer
11
USB cable issue
I have this weird issue with my USB cable. On computer works fine, but on my laptop is nightmare :unhappysweat: . I connect my phone and it constantly keeps me connecting / disconnecting which is annoying ! How can i fix this ? Thanks !
Re: USB cable issue
There is no one answer but a few possibility's
Does it happen with all USB cables or one one. If so this USB cable is "bad".
Is it possible that the drivers for your phone are correctly installed on your PC but not on your laptop this could also explain this annoying problem you have.
Good luck
Re: USB cable issue
I have one cable. I tried to reinstall drivers in device manager but no hope.
YeOldRam
