USB powered portable LCD monitor -- work on Surface?
apoc527
201
Im going to be getting one some time next month for my desktop, so ill try it with my surface anyway so if you don't get a response of find an answer just hold out
I dug this info up from there website also if it helps. How many Mimo monitors can I connect to my PC?
Theoretically a PC can recognize up to 127 USB devices! However, with current PC systems, we recommend the following maximum number of Mimo displays:
1-2 Mimo displays: 1.2 GHz CPU / 512 MB RAM
3-5 Mimo displays: 1.8 GHz CPU / 1GB RAM
6 Mimo displays: 1.6 GHz Dual-Core CPU / 1GB RAM
as for actual power im not sure because it says it has a second usb connector if you need additional power.
sixsigma
