Windows 10 Build 14925 Battery Drain And Charging Issue
Trq20
37
I just wanna give tips, if u on build 14925 and having battery draining fast, and also charging issue, dont update the extra and info if u reset it, if you have w10 extra and info, u should reset it i think, because that one have problem with this battery, also Lumia motion data, dont update, your life will go safely and beautifull without battery issue, hehe, good luck.
Or just keep everything on, but in Windows Insider just switch to Production builds....Battery should go back to 24 hrs.. :D
