Xbox 360 slim power supply fan.
WasteSomeTime
870
Hello, the power supply fan is making a loader noise than the console. Does this mean I have to replace it? Can I use the power supply from the original Xbox 360? Also if I don't replace it, will a power surge or anything like that cause damage to the slim?
Coreldan
2,514
My friend borrowed his 360 to me while he was out of town and I was surprised how much noise the power supply was making. I shut down the console and left the room and soon started wondering if I still didnt turn it off cos of the noise coming from the living room, it was the power supply :D But it wasnt behind the TV set etc at that time, cos I only had it for such a short time that the power supply was basically in front of the TV so it was more audible than if it was in a more usual place.
Can't really answer your question, though.. :D
TrueGamer
11
Your Power Supply should be fine
My Xbox 360 S power supply humms and its not noticible while you playing but as a precaution try spraying it out with a can of compressed air as dust and debris might have settled on the fan causing it to hum louder
ryan.shultz
