Hi everybody!
I bought the Nokia Lumia 820 last week on sale (~200?), after have used a Nokia Lumia 710 for two years... The differences between the two smartphones was impressive, but since the first day I noted a massive battery drain: I read a lot of topics about massive drain battery on Lumia 820, but if I remember right all the topics were about "not new" cellphones and for this reason I opened a new topic (I'm sorry if I did something wrong ). Anyway when I turn on 3G connection (H+ mostly) or Wifi, the battery charge falls down about 2% every 5 minutes (also with "saving battery charge" mode turn on). I keep only whatsapp active in background, I set the brightness on the loewst level, I turned off the "high sensibilty" for the touchscreen, and set to off the NFC and GPS mode. But I always suffer of that massive drain..
My questions is: because my cellphone it's new, it could be possible to be a problem with the battery? Or that's normal for that cellphone? I'm asking that because with my old phone I never suffer of a so massive battery drain (ok, it was based on windows phone 7.8, so I can't compare it with my actual phone).
Thanks to all for the help. :wink:
Greetings from Italy
Enrico
Enrico
