Lumia 930 Battery meter or battery problem question
loukkis
53
When I charge my phone overnight and take it out of the charger in the Morning and when I look battery meter, it is fully charged. After 15 minutes and no use at all, when I check battery meter, it is somewhere in 93-94% readings. After that "rapid discharge" everything seems normal, battery level drops 1.5%-3% per hour. Does your phone do that or is my phone or battery broken?
Racing Snake
418
Mine does exactly the same, no idea why... psychologically I want it to stay at 100% for longer than 10-15mins, even if it does seem to perform well after that!
Headfx
5
I'll charge the phone till it says 100%, but if I then restart the phone the meter will sometimes read around 93/94%. One time this week I restarted the phone while the meter was at 83% and when it came back it read 100%! Then it dropped back to about 83% a few minutes later. Something definitely screwy going on I think.
iwang
20
I remember days of android batter meters...reset..hard reset..clear dalvik..etc..now my 930 is not yet consistent..still learning on where is the,0 and where is 100%
DrPendragon
