Different Battery Level after Soft Reset
Chee Hong
39
Tried just now. Firstly the battery level showed 44%. Then I did a soft reset. It showed a 28%. Then I tried another soft reset. It showed a 37%. Then I tried another soft reset and it showed 34%. Any comment on this? Or it is just normal?
WanderingTraveler
4,974
It's most likely Battery Meter recalibration. That's it. Bear in mind that you're supposed to lose some power when you soft reset. It takes a lot of power to reboot while resetting certain system settings, after all.
Carnes
