How can I fix a loading start screen problem I am having in Windowsphone Build 10080?
Windowsphone build 10080 -Loading start screen.
Does anyone knows of a permanent fix of the loading screen, because a hard reset does the job but when I set my date correct I still receive the loading start screen error...
Re: Windowsphone build 10080 -Loading start screen.
The only permanent fix for windows 10 preview bugs is to roll back to 8.1 and stay there.
This is a preview so nobody can give you a 100% fix.
Harrie-S is right.
Some issues will be fixed in the next release but it will include new issues.
Decided to stay with 10080 until because of the new Office and music preview app.
The delay to show de start screen comes and goes. Usually a soft reset fixes it for sometime, but it will come back.
Good luck!
I guess it's fixed. I was unable to use my 1520 properly because of this loading screen but since yesterday the phone restarted on its own a couple of times and now it seems to have been fixed.
niedrie
