Windows Central Question
Hello. So recently I checked out the option of upgrading to 64 bit because my friend who I got this computer from said his dad installed 32 over 64. Saw the article here to look at System Type and if it says "Under System type, you will see two pieces of information: if it says 32-bit operating system, x64-based processor, then it means that your PC is running a 32-bit version of Windows 10 on a 64-bit processor." And it says exactly that when I look at it. However right after I noticed it said alternatively you can check System Info, which I did and it's saying "x86-based PC". So I literally have a paradox going on, they both can't be right obviously and I don't want to screw my computer up. Any clarification would be great!
