Blu win hd lte Battery Draining....
PG2connect
29
Hi ,
I use BLU WIN HD LTE in which battery starts draining when ever i connect to internet by turning "cellular data on or wifi" immediately my battery starts to dip. Over normally without turning on the data or wifi... the battery is good. Can some one suggest some good charger... i use the 1amps charger it takes 3.5 hours to charge fully.
Mine is still in windows 8.1 update 2.
I switched off phone and pressed that reset button for 30 seconds. It remains the same...
Thanks
PG.
Chintan Gohel
May 23, 2014
10,785
36
there must be some process that is using data - so check what can run in the background and disable. Auto updates of apps, auto upload of photos, etc
Also, try getting a new SIM card
PG2connect
29
While using cellular network I disabled the auto updates for apps and photos. I can see huge difference in battery stability. It really helps.
Thanks
PG
Carnes
