Keith Wallace
Re: AMD vs Intel
He's already mentioned this stuff in the thread.
Budget: 400-500 Euros
Resolution: 1680x1050 (no mention of FPS, but I imagine 30 FPS is acceptable, 60 FPS is ideal)
Graphics: Diablo 3 at highest settings, low-to-medium settings for games over the next 3-4 years
But the main thing here is that it's a very rare occurrence that AMD is the answer nowadays. Games won't use more than 2 cores in a lot of cases, with 4 being the absolute most. That can make the 6- and 8-module FX processors from AMD a bit of a waste, because not all of the modules will be utilized fully. On a per-core basis, Intel's Haswell stuff will take the AMD stuff to school anyway. At the low end, where you'd probably find the FX-6300, the i3-4130 should beat it almost every time. One you get to the i5 stuff, it's game over for AMD. Even if you were to go with a Sandy Bridge 2500K, you'd probably beat an FX-8350.
The only time you'd maybe recommend AMD is if the person wants to do an extremely-cheap build for the next couple of years, at which point a Kaveri APU can probably get recommended. Since the OP is talking about 3-4 years down the road, an APU probably won't keep up.
The best way to find out what is right for you is first identify your budget. Next, what are you planning on doing? You have chosen gaming, great! Now we can proceed to the next step. Do you want medium, high or ultra graphics? Do you want to play at 720p 30FPS, 720p 60FPS, 1080p 30FPS or 1080p 60FPS or are you planning on going higher like 2160p @ 120 FPS. Ok I must say there is a lot of debate on wether120p is worth it or not considering a lot of studies say after 87FPS we as a human cannot see the rest but if you're all about boasting your specs you can go to 120FPS.
Once you have Identified which one of these routes you are going to take you can pretty much decide on Intel or AMD. Good luck.
Just so you know I play Skyrim on 1440p @ 60FPS on High grapics. Ultra will put be at about 20 ish FPS but can play on 1080p @ 60 FPS on Ultra and I have a $500 computer using AMD Chipset and AMD GPU. The reason I use Skyrim is because its my most demanding PC game at the moment. I do not play Battle Rising Duty or whatever that popular game is.
