i need help with emipsx
Nokia Boy
568
Hey guys i downloaded emipsx and loaded the CMR2.0 rom to play it -i lovoe this game-,even though i setted the game bias to 2 it stil lags a lot,which are best options for EmiPSX for the best perfomance?
Oct 26, 2013
93
1-Download BIOS to sd card and copy to internal.(also enable BIOS)
2-BIAS to 2
3-Frameskip:-Auto.
4-PSX CPU speed :- 60%
Both of my compatible games "silent hill" and "Tekken 3 " work smoothly on these settings :)
Oct 26, 2013
93
Colin McRae 2.0 still lags on my Lumia 520
I tried almost 9 games and only the 2 mentioned above worked,Maybe after next update we will get more compatibility and games will not lag,I used the settings above and Tekken 3 and silent hill worked at,I would say 90% performance on my nokia lumia 620,try every configuration,you might get lucky.... :)
Carnes
