1. Chuck Foltz's Avatar
    So I upgraded from base phone model for months up through to the current fast ring with the Firmware update installed. Since the firmware and OS both updated at the same time I'm not sure where the issue is. My battery lasts about 4 hours max with light usage. When I got to battery usage I see an app called START using most of the battery. So I think its maybe my icons etc. I have maybe 10 icons on the start screen and about 3 of them have notifications. The phone is running HOT so I'm guessing something is eating or hammering the CPU. The phone is lagging quiet a bit for text inputs etc. I will be factory resetting from the OS and re setting up my phone. We will see if this helps. I haven't seen any posts about battery and start usage recently so... If anyone else noticed this chime in.
    Also I noticed that the start icons do not update all the time. When I load email I see like 15 emails but no count on the icon. I know they recently changed the way they refresh so maybe this is the issue.
    Trying to tough it out till next update of course.
    03-21-2016 02:04 PM
  2. J H4's Avatar
    Factory reset - I HAVE to do this every update. Painful, but it works.
    03-21-2016 02:32 PM
  3. ceno666's Avatar
    I think you should reset the phone, i had the same problem and now it runs flawless with latest fast insider build
    03-21-2016 02:33 PM
  4. Chuck Foltz's Avatar
    Yeah I don't mind a factory reset as I like the clear mind :) Ill let you know if it works
    03-21-2016 02:33 PM
  1. Is my Lumia 625 going to update to W10M or not?
    By marceltapi in forum Nokia Lumia 625
    Last Post: 03-22-2016, 03:09 AM
  2. Why is my battery draining so fast on Windows 10 Mobile?
    Last Post: 03-21-2016, 01:39 PM
  3. Replies: 2
    Last Post: 03-21-2016, 01:37 PM
  4. How Microsoft showcases Lumia and Surface in Quantum Break
    Last Post: 03-21-2016, 01:11 PM
  5. My new Lumia 640 got stuck on the Gadgets app and doesn't go from it. What do I do?
    By Windows Central Question in forum Microsoft Lumia 640
    Last Post: 03-21-2016, 11:41 AM
