Hi everyone, I have had my SP3 i7 model since August with no problems (love it by the way, it has completely replaced my PC/Laptop).
I was using it today as per normal when suddenly the touch screen was acting a little strange. I rebooted several times, even did the 'volume up and power on' button a few times but the issue persists. The unit is set to auto update and there haven't been any updates within the last day or so from my recollection so it can't be a bug.
The problem is that t I am only able to scroll up or down (and it's not very smooth). I am unable to open any tiles or apps (windows home screen) or interact with the screen (i.e. zooming in/out etc). Basically I can only do very basic touch functions. Also now when I start the SP3 and see the log in screen, there's always a visible repetitive touching animation to the right in the same spot as if I was pressing that spot (almost like a ghost was repeatedly pressing it ). I hope I've been able to describe the problem clearly.
The repair center is pretty far away so I'm hoping if anyone has had a similar problem or knows about it could kindly shed some light on the issue please?
Thank you.
Thank you.
